Comme beaucoup se pose cette question récurrente, j'ai décidé de récapituler mon matériel de charge pour la gamme 1/16 de traxxas (e-revo et slash, drifteuse sur base d'e-revo...).
Biensur la config chargeur / alimentation est valable pour tout modèles (1 à 18 nimh, lipo jusqu'a 6s, pb, ca laisse de la marge...).
J'ai commander tout mon matériel chez Hobbyking (http://www.hobbycity.com).
Le choix du chargeur pour moi : petit chargeur relativement bien noté et me permettant de charger mes autres accus (nimh & pb)
An advanced and powerful charger, the Turnigy A6-10 is able to charge, balance and discharge Lion, LiPo, LiFe (A123), NiCd and NiMH batteries on a maximum output power of 200W. It can charge or discharge up to 18 cells of NiCd / NiMH and 6 series of lithium batteries with maximum current of 10A. It can accept three types of Lithium batteries (Lilo/Lipo/LiFe).
Features;
Microprocessor controlled
Delta-peak sensitivity
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 10~18v
Circuit power: Max Charge: 200W / Max Discharge: 25W
Charge Current Range: .1~10.0A
Discharge current range: .1~5.0A
Ni-MH/NiCd cells: 1~18
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~24v
Weight: 540g
Dimensions: 143x124x37mm
Turnigy T-20Pro can supply a constant and solid 16A at 14v.
Even if you dont charge at high rates, having a solid power supply like this will ensure the charger is supplied with a good constant current, helping it to balance cells more accurately.
The charger will suit 100-240v 50-60Hz home power points. The plug is a common kettle/laptop type, so it will be easy to source a local power cord.
Spec.
Output: 14VDC (220W)
Input: 180~240V (50~60Hz)
Important.
Internal fan thermostat set to 60Deg Celcius. Fan will not run unless power supply internal temp reaches 60DegC.
Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries in the hobby market today!
Spec.
Capacity: 2200mAh
Voltage: 2S1P / 2 Cell / 7.4v
Discharge: 20C Constant / 25-30C Burst
Weight: 123g (including wire, plug & shrink wrap)
Dimensions: 100x34x17mm
Balance Plug: JST-XH
Discharge plug: XT60
Pour ne pas s'embéter à souder et profiter directement de la connectique du chargeur et des accus
En complément de la plaque fournie avec le chargeur. Cette plaque permet de charger / équilibrer 3 lipo 2s ou 2 lipo 3s en même temps.
Il faudra biensur prévoir du cable et des connecteurs pour faire un triple (pour 3 lipos 2s) ou un double (pour 2 lipos 2s ou 2 lipos 3s) cable d'alimentation pour les accus. cf plus bas
Pour fabriquer les cables pour la charge simultanée de plusieurs accus en même temps.
(http://www.hobbycity.com/hobbyking/stor ... oduct=9673 et http://www.hobbycity.com/hobbyking/stor ... oduct=9674)
Photos de l'ensemble :
Voilà j'espère que ça en aidera plus d'un!
Manu
