RC4WD Hardcore Slash G10 Upgrade Kit
Hardcore Slash upgrade kit is a beast when it comes to scalism and performance. Radically engineered from ground up with the purest racing breed in mind. This kit is the first production Short Course upgrade that comes with a CNC machined short course straight axle and G10 graphite chassis. Rear racing inspired suspension setup allows optimal and precision cornering at high speed. Hardcore axle comes with full differential and custom made spool for the transmission provides better stability and control in lose dirt and offroad track conditions.
Important Note: All orders will be shipped within 1-2 weeks, we are taking pre-order now. Limited quantity available on first patch.
Low Center Of Gravity (COG)
Ralistic rear suspension
Billet aluminum hardcore axle with differential
Billet trailing arms
Billet lower suspension arms
High performance rear shocks
Machined suspension links
28 Tooth hardened pinion gear
Steel hardened drive axle
Steel punisher drive shaft
Full ball bearings
Billet suspension links with metal rod end
Black steel button head hardware
High performance rear shock and shock oil
This kit require a complete Traxxas Slash 2WD
Total parts: 90+
Engineeered by RC4WD Team United Kingdom (UK)
$349.99
https://store.rc4wd.com/Hardcore-Slash- ... _1085.html
