Voici le nouveau crawler 1/10 de Losi le COMP CRAWLER. Les liens pour les autres infos en bas de page.
Features
Compact Front & Rear Locking (DIG) Center Transmission allows the crawler to overtake obstacles with ease
Front and Rear Solid Axle with Worm Gear Drive
4-Link Suspension offers 70 degrees of articulation and minimizes front and rear axle swing, allowing for more precise handling
Zero Ackerman Steering provides class leading performance with 45 degrees of steering throw
Front and Rear locked differential provides full time 4wd
3-Piece 2.2" Bead Lock Wheels with aluminum outer rings
National Champion 2.2 Losi Rock Claws Tires with foam inserts
Twin Vertical Plate Chassis with adjustable upper shock mounts
4" Aluminum Threaded Shocks with Titanium Nitride (TiNi) Shafts allow the suspension to articulate without any binds.
Durable, telescoping CV drive shafts allow for increased steering range
Aluminum Upper and Lower Suspension Links for added strength
Lexan Grappler Pro body is optimized to USRCCA Rules and allows for clearance of the tires as they articulate
Race Roller Chassis is preassembled; simply add electronics, paint the body and go
Product Specifications
Type:Competition 2.2 Rock Crawler Race Roller
Scale:1/10 (2.2)
Length:17.5 inches (444.5mm)
Width:10.5 inches (266.7mm)
Wheelbase:12.5 inches (317.5 mm)
Weight:4.18 lbs. (1.9kg)
Chassis:Twin Verticle Plate
Suspension:4-Link
Tire Type:National Champion Losi Rock Claws 2.2
Wheel Size:2.2" Bead Lock
Kit/RTR:Race Roller
Shock Type:4" Aluminum with Titanium Nitride (TiNi) shafts
Body:Clear Lexan Grappler Pro
Completion Guides
Basic
Advanced
Needed to Complete
Basic set-up
• 17.5 T Brushless Motor and ESC (LOSB9553 Xcelorin Sensored 17.5T ESC/Motor Combo)
• 2-3-Cell LiPo (LOSB9865 11.1V 1350mAh 3S 20C LiPo)
• Charger for above battery (LOSB9605 Intelligent Lithium Charger)
• High torque Steering Servo (Min. of 200oz) (JRPSZ9100T Digital Ultra-Torque MG Servo)
• 2 Channel Radio System
• Paint
Advanced Completion: To take full advantage of the DIG set-up and the true potential of the 1/10 Comp Crawler
• 3-Channel Radio System w/ 3 position 3rd channel switch (SPM3130 DX3R DSM2 Radio System)
• Mini Steering Servo (LOSB0822 MSX12 Digital Mini Servo)
http://www.losi.com/Products/Default.as ... D=LOSA0051
