Je ne sais pas si ça a été posté sur MMT mais je ne crois pas, vu sur le site Tamiya USA le tout nouveau
The 801Xt is a 1/8th scale competition level assembly Truggy kit, designed and tested in Southern California, USA. The highly efficient drive system comes from the optimized placement of the front and rear propeller shafts. The drive-line is virtually straight, which offers the most efficient drive-line possible in its class. The 801Xt chassis has plenty of adjustability to fine tune it for the most demanding of race tracks across the globe. TRF drivers from all parts of the world will be piloting this new competition level Truggy in the coming months in an effort to exploit its potential and further develop the new line of 801Xt options soon to come!
Kit Features
3mm A7075 hard anodized Duralumin chassis
Machined aluminum shock towers, steering knuckles and engine mounts
Low wear, efficient straight line drive train
Carbon fiber servo plate and upper decks
Sealed radio box
Full ball bearings
Sealed bevel gear differentials
Spiral cut ring and pinion gears
Lock nut captured suspension hinge pins
Universal drive shafts
3 shoe aluminum clutch
15mm Large volume shocks with boots
17mm wheel hubs
Front and rear stabilizers
Turnbuckle brake linkage system
Dual 32mm brakes
High volume air filter
Low profile polycarbonate body
Adjustable turnbuckle linkages
Chassis side guards
High down force wing
150cc fuel tank
Specifications:
Wheelbase: 373 mm-375 mm
Width: 428 mm
Length: 566 mm
Dry weight: 9.2 Lbs (varies on radio gear & engine)
Gear ratio: 15.35:1-16.54:1
Fuel capacity: 150cc
Engine size: .21-.28cc
Separately required items:
Engine .21-.28cc
Manifold & pipe
Fuel filter
Tires & Wheels
Two Channel radio with two high torque servos
6.0 V reciever battery
Fuel
Paint for Polycarbonate body
NITRO KITS REQUIRE:
(unless stated differently above)
Radio: 2-Channel with servo(s)
Battery: 4 AA for Receiver
Fuel: Nitro Glow Fuel
Starting Equipment: Glow igniter
Paint: Polycarbonate for spare body
Misc. Items: Building and track equipment
