Une petite news de chez FLM : un chassis qui permet de faire deux choses :
- soit de passer son savage en e-savage, tout en utilisant les trains avant et arrière du savage
- soit de passer son e-savage en un e-savage sur base de savage pour plus de solidité (reprend les trains arr et av du savage)
Ca peut être sympa pour ceux qui veulent mettre un gros BL sur leur savage, tout en reprenant à la fois les structures du E-savage et Savage. Bon j'avou c'est un peu le bordel à comprendre tout ça, j'ai encore du mal à comprendre dans quel sens ce kit est réelement fait pour...E-Savage Nitro Conversion TVP's
These TVP's will allow you to use all nitro savage parts
which are considerably stronger. If you purchase these
TVP's you HAVE TO purchase all the Nitro Savage
chassis components. Whether you purchase the parts
from us or you use stock Nitro Savage parts, either way
you will need Bulks, Diff's, Shock Towers, Skidplates,
and Arms. You can purchase the items needed in kit
form below.
The E-savage is an impressive truck except for its
inability to handle any more than stock power. With the
advancement of brushless technologies being so
powerful this was the only way to truly bullet roof your
E-Savage
Included with this Conversion you also get Dogbones
for the front AND rear driveshafts going from the
transmission to the Diff's further strengthening the
driveline.
The conversion will accept virtually any motor including
the largest motors available from all popular companies
we have tested with room to spare.
This kit will also work if you want to convert a Nitro
Savage to an E-Savage. You will only need to purchase
an E-Savage trans and motor/ESC.
Prix : 100$
http://www.addicted2rc.com/E_Savage.html
Qui tentera ?
Fab.
