Toutes les spécifications :
Flux Motiv Brushless ESC
Features:
6-8 cell NiMH / NiCd or 2 Cell Lithium Polymer (with 5700Kv Motor)
6-12 cell NiMH / NiCd or 2-3 Cell Lithium Polymer (with 4600Kv and below Motor)
70A* Continuous / 380A burst current
Ultra low resistance (.0007 ohms / phase)
Sensorless technology eliminates additional sensor wiring and complexity
Lithium Compatible**. Programmable Lithium under-voltage cutoff protects delicate Lithium packs from over-discharge
*25C temperature, 5mph air flow through heat sink minimum. Burst current: < 2 seconds duration, 1% Duty cycle
**ESC must be programmed for Lithium cutoff when using Lithium batteries.
Flux Warp 5700Kv Brushless Motor
Features:
Oversized precision sealed bearings
2.3mm 1/8" Hardened Steel Shaft
Slotless stator design delivers smooth, linear torque
Triple insulated windings for long life
#100416 Flux Motiv Brushless ESC
#100420 Flux Warp 5700Kv Brushless Motor
#1511 Flux Brushless System
Source : RC forum.kr
