tout se quil a dessus
OPTION
chassis carbone fait maison
amortisseur hyper 8
cardan cvd MIP
renfort carbone fait maison
renfort alu central sous le moteur fait maison
sabot alu av ar fait maison
renfort de cage alu fait maison
hexa de 23 gpm
filtre a air rb
servo direction futaba s9351 13.8kg 0.13 secondes digital
servo gaz futaba s3010 6.5kg 0.20secondes
MOTEUR
picco p3 28
reso 0207
embrayage alu 3 point resort 1 cloche k factory ventilé 17t
REGLAGE
huile amortisseur av 600 piston 3 trou ar 300 piston 2 trou
huile de diff graisse roulement
PNEU CARROSERIE
bow tie serie 40 jantes blanches velocity
chevy silverado 2007 pein a areographe
et bein voila le tnx
![Image](http://img253.imageshack.us/img253/8381/spa0147nw5.jpg)
![Image](http://img213.imageshack.us/img213/7052/spa01331up3.jpg)
![Image](http://img213.imageshack.us/img213/8937/spa0139za5.jpg)
![Image](http://img101.imageshack.us/img101/2900/spa0122di1.jpg)
![Image](http://img101.imageshack.us/img101/8748/spa0096te4.jpg)
![Image](http://img101.imageshack.us/img101/827/spa0074nz9.jpg)
![Image](http://img101.imageshack.us/img101/2680/spa0093cm3.jpg)
![Image](http://img101.imageshack.us/img101/1296/spa0123se1.jpg)
![Image](http://img122.imageshack.us/img122/1896/spa0153rq6.jpg)
![Image](http://img122.imageshack.us/img122/4994/spa0079zl6.jpg)
![Image](http://img122.imageshack.us/img122/1641/spa00731gj7.jpg)
