![Cool :cool:](./images/smilies/icon_cool.gif)
et bien LOSI nous prépare un LST3...
"boite 3 vitesses, 8 amortos, etc etc..."
http://www.killerhobbies.com/items/un-a ... detail.htm
Pas de photos, mais un descriptif de la future bète
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
A voir pour le mois de mais.
Eric
Key Features
* Potent new 2-port Mach 429 engine
* Newly-designed driveshafts, bearings and axles for added strength
* Revised RPM suspension arms, hubs, carriers and spindles
* 24mm anodized aluminum wheel hexes
* 8 Mega shocks with threaded anodized bodies and adjuster nuts
* Losi pull-Start Electric Starting System
* Exclusive Multi-speed 4 speed transmission w/reverse and slipper clutch
* Sealed 3-speed spur gears
* Plastic-geared vicous differentials
* Bulletproof plastic F/R differential cases
* 430-series dish wheels
* Low-profile MTX racing tires
* Plastic clutch shoes
* High-capacity fuel tank (90cc)
* Dual-disk brakes
* Pro-tune linkage set
* 400 MAH Ni-MH receiver battery pack and 110V charger
* Dual plastic-geared Z590 steering servos
* Premium JR XS7 Synthesized radio w/5 steering servos
Specs
Length: 29 in (559mm)
Width: 22.5 in (470mm)
Wheelbase: 18.2 in (361mm)
Weight: 19 lbs. (5897g)
Chassis: Dual-deck aluminum with composite ladder braces
Suspension: 4-wheel independent H-arm
Drive Train: Center Hi/Lo trans, 2-speed w/slipper and 2 differentials
Tire Type: ATM low-profile racing tires
Motor or Engine: Mach 429 (.427cc) with tuned exhaust system
Radio: JR XS9 Synthesized FM system
Servos: Z590 (steering x 4), Z270 for throttle/brake & shift
Batteries: 400MAH NiMH receiver pack
Charger: 110v, 100MAH overnight charger
Speed: 70+MPH
Wheel Size: 40-series using 24mm drive hex
Kit/RTR: RTR
Shock Type: Oversized threaded coil-over mega shock
Body: LST2 Racer type, prefinished
Ball Bearings: Complete
Fuel Tank Capacity: 90 c.c.
Needed to Complete
8 "AA" alkaline batteries (for transmitter)
Fuel (45% nitro Blue Thunder or equivalent)
Fuel Bottle
7.2v battery and charger (for Spin-Start system)
"C" Alkaline battery (for glow igniter)
en parlant de canulard, le rodage, il en est ou?kazeba a écrit :C'EST un canulard…ou c'était…ça date du 1 avril
http://lstforums.com/forums/viewtopic.p ... light=lst3
