Type: 2WD Stadium Truck RTR
Scale: 1/36
Length: 4.5 in (114mm)
Width: 3.5 in (89mm)
Wheelbase: 3 in (76mm)
Weight: 3.4 oz (96g)
Chassis: Composite tub
Suspension: Independent
Drive Train: 3-gear transmission w/gear diff and slipper
Tire Type: rubber multi-pin rear/ribbed front
Motor or Engine: Micro Electric
Speed Control: Electronic Forward/Reverse
Radio: 27MHZ AM Pistol
Servos: Sub-micro
Batteries: 4.8v, 150MAH NiMH (included)
Charger: Peak (included)
Wheel Size: 0.75 in (19mm) diameter
Kit/RTR: RTR
Shock Type: Coil-Over Friction Dampers
Body: Factory-decorated Stadium Truck
Ball Bearings: BB-Equipped Transmission
rien à ajouter tout y est mêmes les piles!
source radiocontrolzone
