CARSON Expert Charger
Forum dédié aux chargeurs de modélisme et alimentations.
jafred74
modèle(s) possédé(s) : HPI NITRO RS4
Message par jafred74 » ven. sept. 18, 2009 15:43 pm
Que pensez-vous de ce chargeur ?
Chargeur CARSON Expert Charger SPORT (Charge/Decharge, Delta peak) : 80€
Scope of delivery:
Carson Xpert Charger Pro with 12 V connecting cable (50 cm), 230 V connecting cable (1m) and manual-CD
Technical Details:
Input voltage:
* +230 V AC, 50/60 HZ
* + 10.5 to 15 V DC
* current drain Charge: AC/DC max. 75 W, DC max. 130 W
* current drain Discharge: max. 25 W
* charging current: 0.1 to 6.5 A
* discharging current 0.1 to 6.5 A
* Measuremets: LxWxH 188 x 163 x 77 mm
* cooling fan
manually adjustable charging parameters:
* 1-99 charging-/discharging cycles, adjustable
* 10 program saves
* adjustable cycle breaks of 1-10 minutes
* adjustable charging end voltage per cell (5 to 20 mV/cell)
* Automatic charging program
* Warm Up Charging function NiCd/NiMH
* Battery types:
* 1-8 cells LiPo/Lilo/LiFe (A123)
* 1-24 cells NiMH/NiCd
* 1-6 cells PB (Blei, 2-12 V)
Information during the charging/discharging process on the display:
* battery type and cell number
* charging state
* Ampere
* charging/discharging time
* input voltage
* charging end voltage Delta-Peak
* capacity
* temperature
* data save
Modifié en dernier par jafred74 le dim. sept. 20, 2009 11:10 am, modifié 1 fois.
jebasse
Re: CARSON Expert Charger
Message par jebasse » sam. sept. 19, 2009 23:13 pm
je ne comprends pas l allemand, mais j ai cru comprendre qu il ne faisait que 50W...c est tres faible je trouve, surtout pour les futures lipos a charge rapide...
Jean
rustler dopé au Mamba Max, aq a123 3s
asso t4 basic 5300 aq a123 2s
jafred74
Message par jafred74 » dim. sept. 20, 2009 11:11 am
En Anglais :
Scope of delivery:
Technical Details:
Input voltage:
* + 10.5 to 15 V DC
* cooling fan
* 10 program saves
* Battery types:
* charging state
* Ampere
* input voltage
* capacity
* temperature
* data save
http://www.carson-modelsport.com/en/pro ... =500606041
http://www.rcteam.fr/p3442/CARSON-Charg ... _info.html
jebasse
Message par jebasse » dim. sept. 20, 2009 13:33 pm
ok il a l air pas mal, comme beaucoup de chargeurs aujourd hui.
par contre il me semble que tu confonds le sport et le pro (sport: 50W et pro 130W)
si tu veux du 50 W pas cher tu as ca:
http://www.hobbycity.com/hobbycity/stor ... er/Charger matos tres honnete.boutique ok
sinon le meme en 150W et sonde temperature:
en okaz tu peux trouver des chargeurs style ICE ou autres dans cette tranche de prix....
le truc pour le carson c est de trouver des renseignements d utilisateurs, pas evident
Jean
jafred74
Message par jafred74 » dim. sept. 20, 2009 18:06 pm
Merci jean
Je prendrais le PRO si jamais car il y a juste 20€ d'écart !
Pourquoi dis tu qu'un 50w est faible ?
En fait je veux juste éviter de commander à 3 endroits différents, ton lien est pas mal par contre !
jebasse
Message par jebasse » dim. sept. 20, 2009 19:49 pm
ben 50W, ca fait par exemple maximum 6A pour un pack de 2s lipo (8.4v X 6A= 50W).
quand tu auras un pack lipo de 5000mah capable d etre charge a 2C (en 1/2 heure), il te faudra 10A X 8.4V= 84 W. sous 4C (charge en 15 a 20 min) 20A X 8.4V= 170W. la il faut evidemment le chargeur qui monte a 20A et 170W.
avec 50W, tu seras planfonnne a 6A quel que soit ton aq lipo 2S (charge en 1H).
ceci dis si tu ne fais que de l auto RC toujours sous lipo 2S, ca pourrait suffire, c est vrai je resonne en considerant mes packs 6s lipo d avion !
Jean
jafred74
Message par jafred74 » dim. sept. 20, 2009 21:57 pm
Ok merci beaucoup !
jafred74
Message par jafred74 » lun. sept. 21, 2009 11:48 am
Encore une question :
Faut-il que le chargeur monte à 10A ou 6.5 en charge sont-ils suffisants pour charger à 2C des lipo 2S
Car tu mets :
jerome.nimo
Message par jerome.nimo » lun. sept. 21, 2009 12:26 pm
toout dépend de la capcité de tes lipo..
chargeur Icharger 208B
radio spektrum DX6i
jafred74
Message par jafred74 » lun. sept. 21, 2009 13:31 pm
Dans ce cas :
L'Hyperion EOS06510i en promo ici est interessant ?
http://www.miniplanes.fr/accus-lipo-cha ... -1802.html
Et si on veux charger 2 accus en duo (NIcd ou Nimh), il faut quoi ?
jerome.nimo
Message par jerome.nimo » lun. sept. 21, 2009 19:04 pm
il est plus en stock, en ne se produit plus..
prend le 720 chez aircraft world ;)
radio spektrum DX6i
jafred74
Message par jafred74 » ven. sept. 25, 2009 10:37 am
J'ai acheter ce chargeur : Carson Expert Chargeur PRO
Notice :
http://www.files-save.com/fr/download-f ... fe8fe.html
J'ai acheter des accus NIMH 8.4V 4500Mah livrées en prises Traxxas
Mon chargeur a un cable avec cette prise :
Du coup pour brancher mon pack d'accus dessus, je suis obligé d'avoir ce type d'adaptateur :
Maintenant, quelles sont les données a mettre dans le chargeur afin de faire une charge correcte (CF NOTICE)
Mon chargeur :
jafred74
Message par jafred74 » ven. sept. 25, 2009 11:19 am
Voici les paramêtres demandés par mon chargeur :
- Type d'accus : NIMH
- Nombre d'éléments : 7 (de 1.2V) soit 8,4 V
- Intensité de charge de l'accus : 4.5 Ampère
- Intensité de décharge : 1.5 Ampère
- Sensibilité arrêt complet de la charge : 7 mV
- Tension de décharge max par élément : 1 Volt
- Durée minimale de charge : ???
- Nombre de cycles de charges : ???
- Temps de pause entre chaque cycle : ???
Le delta peak doit être automatique et réglable juste pour les batterie Lithium
jebasse
Message par jebasse » ven. sept. 25, 2009 11:35 am
jafred74 a écrit :Voici les paramêtres demandés par mon chargeur :
duree minimale de charge: ce ne serait pas plutot: duree MAXIMALE de charge? si c est cela tu mets 1h15 env.
cycles: ben tu veux faire des cycles charge/decharge?
jafred74
Message par jafred74 » ven. sept. 25, 2009 11:58 am
- Non durée minimale , ils disent ca dans la notice :
Code : Tout sélectionner
Dans le cas de certains accus (surtout lorsqu’ils n’ont pas été utilisés durant une période prolongée), la
surveillance automatique de la tension peut interrompre prématurément la recharge dès la phase
initiale et il faut dans ce cas plusieurs essais pour parvenir à une recharge régulière. Pour remédier à
ce défaut, il est possible d’entrer dans ce masque de saisie une durée minimale de recharge (10 minutes
au plus). Cela permet de sauter la plage problématique et la recharge complète a lieu dans les conditions normales.
- C'est conseillé d'en faire ou pas des cycles ?
jebasse
Message par jebasse » ven. sept. 25, 2009 12:18 pm
ok j ai compris c est pour eviter les "faux delta peak" c est a dire que la tension en debut de charge peut descendre a certains moments, ce qui declenche la coupure par delta peak, donc une charge partielle.
bref, tu mets env 10 min maxi. il faut faire attention car durant ces 10 min, le chargeur n arretera pas la charge, et si tu mets un aq deja charge, il y a danger du surcharge.
pour les cycles, ca sert en principe surtout pour les aq un peu fatigues ou/et toujours partiellement charges/decharges type aq de reception.
jafred74
Message par jafred74 » ven. sept. 25, 2009 12:21 pm
Merci beaucoup :P
Retourner vers « Chargeurs & alimentations »
