>> Nouvelle édition Revo Platinium 2008
Toutes les nouveautés liées au modélisme et plus particulièrement aux monster trucks & grosses roues!
eric 94
Message par eric 94 »
Voici le tout nouveau Revo de Traxxas enfin presque ...
Liste des options :
Larger 150cc Revo fuel tank for superior sealing and consistent fuel delivery during long mains
Sway bar kit with red-anodized front turnbuckles
Hard-anodized, Teflon®-coated GTR shocks
Smooth and durable TiN shock shafts
Variable damper shock pistons
50WT shock oil, orange front & gold rear shock springs
Tight-handling progressive-2 rockers
Digital waterproof servos for steering and throttle deliver 125 oz-in & 0.16-sec transit times
Titanium-anodized chassis and chassis brace
Compact receiver and battery box
Integrated personal transponder mount
Includes rechargeable high-capacity NiMh receiver battery pack and on/off wiring harness
Autoshifting two-speed is simple, reliable, & easy to adjust
Two-speed forward only transmission
Ultra-compact. Fewer moving parts
Low rotating mass for quick, high-revving acceleration
Autoshifting two-speed is simple, reliable, and easy to adjust
Constant drive engagement is smooth and instantly responsive
Sealed case protects gears & 2-speed from damaging track debris
Forward-only transmission reduces rotating mass
Close ratio two-speed gear set for smooth power delivery
High-performance vented front disc brake
Dual-disc rear brake kit with adjustable linkage
Sealed center differential with 500K weight oil
Compact throttle servo mount with air filter support
Mirror-polish Resonator® dual-chamber tuned pipe
Durable spring-mounted header allows pipe movement to prevent impact damage
Ball bearing throttle bellcrank with lightweight return spring
Black silicone exhaust coupler and deflector
Machined aluminum 40mm flywheel for use w/ starter boxes
High-revving TRX 3.3 Racing Engine for proven championship-winning horsepower and speed
Bigger piston and sleeve delivers extreme power
Consistent and smooth throughout the entire power band
Straight-through exhaust flow
Slide carburetor
Knife-edged connecting rod
Large aluminum blue-anodized cooling head
Super-light piston and rod
High-performance ball bearings
Backed by Traxxas Lifetime Engine Replacement Plan.
New high-volume dual-stage air filter
IPS crankshaft and backplate for maximized horsepower
TUBES red-anodized 7075-T6 front and rear toe-links
Red-anodized push rods with steel threaded inserts
Extended wheelbase, adjustable rear suspension arms
Formula-1 style high-downforce black Revo wing
Wing mount offers adjustable height and deflection angle
Response Pro tires with performance-tuned foam inserts
3.8" White dish wheel uses innovative 17mm splined hex that is also compatible with standard 17mm hex wheels
Aluminum 17mm splined wheel hub and hex nut
Includes 17mm molded wheel wrench
New steering components allow maximum steering throw
Large-bearing nylon axle housings with 13mm outer bearings
Steel pivot ball retaining rings
Compact black-chrome bumpers
Blue-anodized antenna crimp nut
Low-profile body posts
50k weight front and 10k weight rear differential oil
Clear, trimmed fastback racing body
Includes the following tuning options:
Tuning shock springs
40WT and 60WT shock oil
Thick sway bars
36-Tooth and 40-tooth spur gears
16-Tooth Clutch Bell
Y-harness for dual steering servos
Enfaite Traxxas a ressortie le meme Revo avec toute les option traxxas et quelque modification (boitié radio , reservoir 150cc , B.A.R modifié , exa ....)
Les nouveaux pneu et jantes ressemble fortement au nouvelle proline LPR ....
Et tous sa pour ..........1200$ sa laisse réveur :lol:
Mais bon c'est sur que après avec un Revo comme plus besoin d'otion il sera fait pour la course apart peut etre le moteur qui sera pas assez puissant face a des truggy :roll:
@+ Merci a chezoit pour l'info de Revopowwwaaa
Xray XT8 + GRP 28 Tuned
lesk8teurdu68
Re: >> Nouvelle édition Revo Platinum 2008
Message par lesk8teurdu68 »
whaoooo ca c'est de l'engin domage que le prix soit aussi élevé :evil:
Le frein fillet tu connais?
megavolts
Message par megavolts »
le prix est élevé c'est vrai mais si on fait le compte en achetant les options à part sa doit être beaucoup plus chere ;)
En tous cas belle machine. Si je gagne au Loto je sais ce que je m'offre :mdr:
olic888
Message par olic888 »
bel engin, mais si j'avais l'argent, je m'orienterais plus vers le sav xl que ce revo truggy......... quitte à prendre un truggy, autant aller vers un mbx5t.
SHARKIES
Message par SHARKIES »
MOI je l'ai dejà vu rouler!!! en vrai,il semble que ce soit le meme que celui de quelqu'un que je connais bien....... ;) ;)
http://www.corsicamonster.com
selon que vous soyez puissant ou misérable vous serez déclaré innocent ou coupable
aricospeedrevo
Message par aricospeedrevo »
magnifique :shock:
Jumpman
Message par Jumpman »
Clair qu'il est magnifique ... même si ça ressemble quand même de moins en moins à un Monster ... et de plus en plus à un truggy. Par contre, les prix donnés sur les sites officiels ne sont jamais (ou presque) les prix réels de vente. Par exemple, à sa sortie, un truggy Losi 8ight-T (Race Roller) était annoncé à environs 1100 USD sur le site de la marque alors qu'il était vendu à moins de 700 USD sur des magasins en ligne.
Moi qui suis pourtant fan de Savage, voilà ici une nouveauté qui m'attire bien plus qu'un Savage XL ... y en a pour tous les goûts ;)
PS : il sera vendu avec une carro à peindre
Message par Yenyen »
Vraiment chouette, mais à quel prix ! :shock:
dr Mabool
Message par dr Mabool »
S'est vrai qu'il est magnifique mais son prix doit l'être aussi.
A mon avis il doit se faire démarré au banc car il n'y a pas d'ezstart ni de tirette surement un gain de poids.
revo tm323
micro baja
SHARKIES
Re: >> Nouvelle édition Revo Platinium 2008
voilà le meme en avant premiere!!!! http://img149.imageshack.us/img149/2531/imag1099jd3.jpg
Ultra
Message par Ultra »
[quote="olic888"]bel engin, mais si j'avais l'argent, je m'orienterais plus vers le sav xl que ce revo truggy......... quitte à prendre un truggy, autant aller vers un mbx5t.[/quote]
Exactement
[quote="SHARKIES"]voilà le meme en avant premiere!!!! http://img149.imageshack.us/img149/2531/imag1099jd3.jpg[/quote]
Je suis pas sûr que ce soit le même car sur les photos du début du post, il y a un pot RB chromée, qui n'est pas sur ta photo ! ;)
ben006
Message par ben006 »
c'est pas le tien ca sharkies, ya le drapeau corse sur l'aileron !?
lexou
Message par lexou »
[quote="ben006"][quote="SHARKIES"]voilà le meme en avant premiere!!!! http://img149.imageshack.us/img149/2531/imag1099jd3.jpg[/quote]
c'est pas le tien ca sharkies, ya le drapeau corse sur l'aileron !?[/quote]
Bein si c'est de l humour
fneyes
Message par fneyes »
C'est un beau Revo, idéal pour ceux qui ne veulent pas se lancer dans la préparation du leur.
Mais c'est vrai que Traxxas n'a rien inventé. Rien qu'en trainant sur le site ou dans ma cave, on trouve ce type de machines avec en plus des moteurs dignes du cassis et d la prépa !
Mais ça reste une très belle machine !
SHARKIES
[quote="Yenyen"][quote="SHARKIES"]voilà le meme en avant premiere!!!! http://img149.imageshack.us/img149/2531/imag1099jd3.jpg[/quote]
Je suis pas sûr que ce soit le même car sur les photos du début du post, il y a un pot RB chromée, qui n'est pas sur ta photo ! ;)[/quote]dejà c'est pas un pot rb,c'est le pot option traxxas, vidé de son cone (par rapport au bleu d'origine),ensuite,vu que celui là sort des ateliers traxxas evidement y a des choses qui ne sont pas tout a fait a l'identique,
SHARKIES
c'est pas le tien ca sharkies, ya le drapeau corse sur l'aileron !?[/quote] ce n'est pas le mien,c'est celui de mon ami FM ,photo prise aux Pennes Mirabeaux,et pour info je suis Corse comme lui
flyers6667
Message par flyers6667 »
[quote="Ultra"][quote="olic888"]bel engin, mais si j'avais l'argent, je m'orienterais plus vers le sav xl que ce revo truggy......... quitte à prendre un truggy, autant aller vers un mbx5t.[/quote]
Exactement[/quote]
Je dis non, enfin, je ne rentrerais pas dans un débat stérile d'anti-REVO et corses ;)
Par contre le Savage XL, il va faire parler encore ...
Mais ce Revo aussi, Traxxas tape encore dans du "Lourd" :)
olic888
loin de moi l'idée d'entamer un débat anti revo!!!! j'adore cette machine, mais surtout dans sa version franchissement et jump!! Par contre, je trouve dommage de faire dun monster un truggy, tant qu'a faire, je pense qu'il y a mieu dans la discipline tel que le mbx 5 (on ne le verra pas en position monster lui..... quoique ;) )
Ultra
Message par Ultra »
[quote="flyers6667"][quote="Ultra"][quote="olic888"]bel engin, mais si j'avais l'argent, je m'orienterais plus vers le sav xl que ce revo truggy......... quitte à prendre un truggy, autant aller vers un mbx5t.[/quote]
Exactement[/quote]
Mais ce Revo aussi, Traxxas tape encore dans du "Lourd" :)[/quote]
je parle d'une engin, tu pars sur autre chose, merci de m'exclure de tes polémiques stériles sans intérêt.
Retourner vers « Forum news portail »
