[NEW] Eurgle 2.4Ghz 3Ch
h.300
modèle(s) possédé(s) : slash 1/10 traxxas bientôt !
h550, blade mCX en hélico
minimag, p51, micro sukhoi SU-26 en avion
Message par h.300 »
Here comes the Latest Eurgle 3 Channel Radio Gear. Pre-installed Fail Safe Function, make a Safer Ride and better protection to your Car & Boat! Upgraded Larger Monitor with Ultra-Bright Background Light, placed on top makes sure you can read clearly!
2.4Ghz provides the most stable and least interference communication. Less crystal minimized your cost for and broden the limit. You can use upto 8 models for this Radio Gear.
Fail Safe Function gives you the best protection to your RC Model. Simply Few-Steps set-up before you run, everthing is under control!
Free Simulator Software compatible, low-cost like spending on FM/AM Radio Gear, why don't have a try?
Features: Fully digital signal, no interference at all.
Less devices - No Module required.
Comaptible with VRC Simulator
ABS System
9 Model Memory
Specification:Transmitter / Receiver : 2.4GHz
Compatibility : Eurgle 2.4Ghz 3 Channel Receiver (3rd Generation)
Power : 8 x AA Battery / 3 Cell Low Current Lipo Battery(Not Included)
Mode Type : Car / Boat
Code Type : Digital
DSC Port : Yes (3.5mm)
Radio Weight : 399g
Receiver Weight : 9g
Cross Weight : 705g
Items included: Eurgle 2.4Ghz 3 Channel 2.4Ghz Transmitter
Eurgle 2.4Ghz 3 Channel 2.4Ghz Receiver
USB Interface
Price: US$42.73
EUR€30.61
http://www.r2hobbies.com/eng/proddetail ... cps2805004
après l'hélico, avion,maintenant auto
pour vos consoles et iPhone : microchip 33
Re: [NEW] Eurgle 2.4Ghz 3Ch
pas trop mal le design ;)
olic888
Message par olic888 »
30 euros??????????? y a pas un suchi la????
bobo30
modèle(s) possédé(s) : hpi e-savage avec Lipos 5200 30C
Localisation : Vallée de Joux, Vaud, Suisse à 5 km de la frontière française
Message par bobo30 »
olic888 a écrit :30 euros??????????? y a pas un suchi la????
C'est vrai que ca fait vraiment peu...
Les Freins c'est pour les lâches!!!
manulesurfeur
Administrateur
Message par manulesurfeur »
6€60 le recepteur supplementaires.
Et bien ca vaudrait presque le coup d'essayer!
Manu
Bestaflex
modèle(s) possédé(s) : Stampede XL5 moddé EZRUN 9T
Message par Bestaflex »
J'ai la version 2ch ancien style et si ça marche pas sur un plan purement technique : programmation, portée, 2.4ghz etc... Sur un plan ergonomique c'est pas la fête : lourde, massive, plastique pas top, 8 piles, menus pas top certaines fonctions gadgets (genre l'abs, pas terrible)
Par contre pour le prix rien à dire.
bouzouk91
modèle(s) possédé(s) : Hpi Baja 5b - Savage 4.6 ss - hyper 8.5 pro - Cen matrix arena
Message par bouzouk91 »
olic888
Bestaflex a écrit :J'ai la version 2ch ancien style et si ça marche pas sur un plan purement technique : programmation, portée, 2.4ghz etc... Sur un plan ergonomique c'est pas la fête : lourde, massive, plastique pas top, 8 piles, menus pas top certaines fonctions gadgets (genre l'abs, pas terrible)
Donc "ca marche pas "sur le plan technique, et ergo pas glop? j'ai bon?
truespace
Message par truespace »
perso, j ai la V1.1 , je l utilise pour 8 modeles (du mini au 1/8 BL) et pour le moment, pas de soucis, ni de portée. On n'est sans aucun doute pas au niveau de spektrum coté poids, ergonomie des menus, qualité des plastiques mais les fonctions principales me vont très bien (selection des modeles rapide, fins de courses, courbes voies 1 et 2, expo, inversion, trim.... le reglage de l abs est effectivement super cheulou !).
Je l utilisais au WRS 2010 (indoor, une centaine de pilotes, bcp en 2.4, micro HF, chemin de câbles sous la dalle de béton, bref, un cadre pas très accueillant coté ondes), et je n ai eu que 3 top radio das le week end donc ça peut aller... :P
Seul repproche que je ferais à la v1: la grosses conso des piles; j ai remplacé ça par un lipo 2200 mah chinois idem que pour less futaba 3pm) et ça donne une autonomie d environ 10 grosses heures entre chaques charges.
Pour cette V2, pas grand chose de nouveau (les recepteurs semblent etre les memes) hors mis le look plutot sympa et le rétro éclairage. Par contre le gros écran placé en position top laisse place à 2 inconvénients: l exposition à la pluie et une + grosse conso.
Mais le prix pèse dans la balance quand on voit les tarifs chez spektrum.
True
Bestaflex
désolé j'ai oublié mal, ça marche pas mal sur un plan technique.
